Results 1 to 8 of 8
Thread: Pixels only turning blue
    12
    Default Pixels only turning blue
    I'm having an issue with some Holiday Coro 2811 Pixel nodes.
    After the first 5 pixels, the rest are just blue. I've tried cutting out the two pixels where the issue starts and connecting it from there as well as connecting the string from the other side with no luck. Any advice on what else to troubleshoot with this?
    I tested these when I got them and there wasn't any problem until now.
    168
    Default Re: Pixels only turning blue
    are you testing them with a sequencer(vixen)
    or from controller?
    try test pattern from controller to rule out patching problems/software..
    or we need more info how you got them setup
    West Bloomfield, MI
    651
    Quote Originally Posted by ebenne View Post
    Which two pixels did you cut out? I'm assuming the last one that worked and the first that didn't work. Is that right?
    Ed
    Happily retired
    12
    I'm testing them directly from the AlphaPix Flex Controller. Other strings connected to the controller are working fine
    12
    Yes, that's right.
    168
    hmmm, what voltage are you using 5/12??
    whats the voltage measure at start of first pixel?
    West Bloomfield, MI
    651
    After you cut out those pixels, you still have only the first five lit and they are blue? If so something is wrong with either power being supplied or more likely, the setup in the controller isn't correct. Did you try lighting the string starting from where you cut out the pixels?
    Ed
    Happily retired
    3,820
    Some strings have a default state of blue after power up. For those strings blue means now data is being forwarded to the pixels. Most likely a configuration error.
