Results 1 to 10 of 14
Thread: ESPixel Stick Problems
    Oct 2009
    709
    Default ESPixel Stick Problems
    Its been a year and I honestly forgot how to program my ESpixel Stick. What info do I enter in the SSID and Passphrase fields in the Flash Tool?
    Programming says its complete but unable to connect to the DHCP so it times out.
    Any suggestions - thanks
    Columbus, OH
    4,263
    Default Re: ESPixel Stick Problems
    SSID = name of your wifi network
    passphrase = password of your wifi network
    Enter the same values as you would on your laptop or PC.
    Without these, you'll never connect,
    Aug 2012
    Nova Scotia, Canada
    1,676
    Quote Originally Posted by covewi View Post
    The SSID and passphrase is the SSID and passphrase for your access point/router.
    The espixelstick connects to the wireless network you define. The SSID is the name of the wireless network being broadcast by your AP/router. The password is the security WPA/WPA2 password you defined for the wireless network.
    Oct 2009
    709
    Thanks - that was easy. Am I using the correct serial port setting?
    1,170
    That looks like the one for programming. it says cp2102 which is one of the programming ones.
    Oct 2009
    709
    Up and running - thanks.
    Oct 2009
    709
    Any reason why the USB to UART option doesnt show up?
    I have re installed the latest Silicon Labs software and still no luck?
    Since I dont see the ESPixel Sticks available on Amazon anymore - does anyone know where to purchase them?
    Otherwise, what would be a good alternative and easy to use?
    Columbus, OH
    4,263
    There are DIY options and other folks make and sell variations of the original pixel stick.
    The DIY option (pixel pop) is available from me and the other variants you can most likely find by google searching pixel stick.
    I'm sure others will reply with actual links.
    Mar 2013
    3
    Here are the two boards that I use in my display:
    ESPixel Pop / ESPixel Pop Tiny (aka: Pixel Pop / Pixel Pop Tiny) - Link
    Renard Plus ESP Pixel Controller Kit - Link
    There are certainly others.
    Oct 2009
    709
    Thanks for all your help - I received my Ray Wu WS2811's https://www.aliexpress.com/item/1953...1af84c4duizgpR today.
    They are beautiful.
