Results 1 to 5 of 5
Thread: Help Config E1.31 Bridge with Renard 4 output controller
    Mar 2017
    Clinton Twp. Michigan
    87
    Default Help Config E1.31 Bridge with Renard 4 output controller
    I have set up my Renard 4 output Controller and all works well as long as I have it connected to my computer. When I try to connect it to my E1.31 bridge I get nothing. I am sure that I am doing something wrong in the bridge setup or do I need to do something to the controller. Can someone tell me what I am doing wrong. I set the bridge I have tried DMX, Renard,ws2811 protocol with universe 6 having 4 channels
    AJVenti
    Oct 2012
    Pleasant Prairie, WI
    1,101
    Default Re: Help Config E1.31 Bridge with Renard 4 output controller
    Have you checked the jumper settings on the board (the output ports)to see if they are set for DMX or Renard?
    Sent from my Pixel 2 XL using Tapatalk
    2012: 24 channels with 1 Renardss24 * 2013: 48 channels with 2 Renardss24's * 2014: Took the year off * 2015: Life Got in the Way
    2016: 1000 Channels for Halloween, mix of A/C, RGB, Pixels. Christmas over 17 universes, all Pixels, oh boy...
    Aug 2012
    Nova Scotia, Canada
    1,675
    You don't connect the 4 output controller to the bridge.
    Both are E1.31 devices so they connect together using a standard switch.
    PC to Switch, 4 output controller to switch and bridge to switch.....they all meet there and have a party.
    P.S. I think you are confusing yourself by labelling it a RENARD 4 output controller, it is actually an E1.31 controller but sold by Renard shop. It has capability of outputting DMX/Renard as well, but it is an E1.31 pixel controller at heart.
    Mar 2017
    87
    Boy did I get it wrong Yes I was thinking that everything went though the bridge. So I need to add a Switch and run one to the E1.31 bridge for my other controllers and one to the 4 output controller. Can I ask one more question? I was going to add another item to my display and I used a Arduino with a DMX shield do I connect it to the bridge or the switch?
    Aug 2012
    Nova Scotia, Canada
    1,675
    Quote Originally Posted by AJVenti View Post
    If it is DMX, you can run from Bridge or from 4 output controller.
    I haven't tried DMX from the 4 output controller so read up on it in the manual as I think it takes a universe from last output.
