Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Suggestions for method/materials for labeling conductors
    7,762
    Default Re: Suggestions for method/materials for labeling conductors
    I've got way too many label makers at the shop.
    I've got a few of the older brady models that were dot matrix based. Aside from the batteries that don't last long, they make awesome labels on anything from self laminating labels, to heat shrink tubes. I believe they were about $800 when they were new. looks like the BMP61 is the closest current model.
    I also have one of the BMP21 models. I'm not a big fan of that one.
    On the Dymo side, their Rhino series is decent. I've got an older version of the 4200 type. I'm pretty sure it's the nylon labels that work the best. They also have heat shrink tubing cartridges that work well.
    Chambersburg, PA
    699
    The other way to use the P-Touch is to make flag labels instead of wrapping around the wire. instead of coiling around the wire, put the center of the label on the wire and bring both sides together on the other side forming a flag. This puts the adhesive sides of both ends together and ends up holding rather well. The only down side is that the flags aren't the neatest thing when managing the wires. But it does allow you to use a bigger font so they're easier to read.
    This is my way of labeling for the past 4 years. All my flags are holding up extremely well. Works much better than trying to label the connectors themselves.
    2016 - No Display
    Nov 2013
    88
    Another vote for the P touch flag method- have used it extensively for work, holds up well.
    Dec 2018
    3
    Do you do anything to keep them attached? (e.g. in harsh outdoor environment, indoor storage heat, over multiple seasons of use?) Looks promising.
    Genreally they hold well, but occasionally I will have one that curls up a little. I've found that some quality packing tape works.
    Oct 2007
    Bundanoon NSW Australia
    265
    I found some 4:1 shrink ratio clear glue lined heatshrink on ebay that was just big enough to go over the connector on some installed pigtails that was still able to shrink down onto the round 3core cable. Can check size when home.
    Folsom, CA, USA
    1,959
    I use a plastic based no tear paper and laser print, then affix with clear heat shrink.
    In Lights Therapy
