Results 1 to 6 of 6
Thread: how do i configure pixlight with vixen?
    Oct 2019
    3
    Default how do i configure pixlight with vixen?
    I was trying to patch the elemnt and controller but i cant proceed on it. any help will be appreciated
    1,197
    Default Re: how do i configure pixlight with vixen?
    screen shot of the patching screen please.
    3,916
    We would also need to know how you have configured your controller(s).
    Oct 2019
    3
    first i configure controller by choosing streaming acn (E1.31) den select as 150 for controller output since the pixel is 50 per string, for my trial purpose, then i press the conigure button and choose size of 150, channel 1 universe 1 den for the element side, i choose generic numbered group first then select 50 as output, then i tried single element then add multiple then put 50 , but my main problem is when i try to run the set-up, only one pixel light is running and working.
    1,197
    Looks like your color handling is not set up on the arch. Select the arch, go into the color handling (gear next to the words color handling) and set it to be rbg or whatever order your pixels are in the arch.
    3,916
    You can tell that color handling has not been set because the number of patch points is 50 and it should be 150
