Vixen 3 Web API Sequence Commands
This year for my Halloween display I have decided to do something interactive and have sensors trigger my various sequences. However I am struggling to figure out the format to Vixen's resting web api. Below is an example of what I have been trying to send.
https://desktop-4rgi471:8888/api/pla...oween+Test.tim
My web server is enabled and I am able to do all the functions just by using the GUI in a web browser but I need direct commands. Any suggestions I appreciate the help as i cannot find any additional documentation or a direct contact at Vixen to ask.
David
Re: Vixen 3 Web API Sequence Commands
Looks like you are trying to do a GET with the parameters as query strings. However it is a POST request with a JSON object in the payload that looks something like this. You won't be able to do that directly from a browser. I suggest using someone like Googles Postman to get the hang of making the restful requests. See this answer for a quick how to set it up.
https://stackoverflow.com/a/38974774
What do you plan to use to send the requests?
"Name":"Announcement",
"FileName": "C:\\Users\\Bob\\Documents\\Vixen 3 - Halloween\\Sequence\\Announcement.tim"
I downloaded postman and was successful in getting the sequence to play. Now I'm struggling with formatting via the Crestron SIO. Below is what the Postman shows as the generated Code Snippet.
POST /api/play/playSequence HTTP/1.1
Host: 192.168.1.22:8888
Content-Type: application/json
User-Agent: PostmanRuntime/7.17.1
Accept: */*
Cache-Control: no-cache
Postman-Token: d5d41686-bb83-4ca5-b666-14702237d626,80aebe38-ab52-47f2-be7f-0cfdf0a3a0f3
Accept-Encoding: gzip, deflate
Content-Length: 123
Connection: keep-alive
cache-control: no-cache
"Name": "Halloween Test",
"FileName": "C:\\users\\David\\Documents\\Vixen 3\\Sequence\\Halloween\\Halloween Test.tim"
Below is what I have been trying to send via Crestron
POST /api/play/playSequence HTTP/1.1\x0AHost: 192.168.1.22:8888\x0AContent-Type: application/json\x0AConnection: keep-alive\x0a{"Name": "Halloween Test","FileName": "C:\\users\\David\\Documents\\Vixen 3\\Sequence\\Halloween\\Halloween Test.tim"}\x0A\x0A
I've also tried to break it down and send lines one at a time.
{\x0A
"Name": "Halloween Test",\x0A
"FileName": "C:\\users\\David\\Documents\\Vixen 3\\Sequence\\Halloween\\Halloween Test.tim"\x0A
}\x0A\x0A
do you get an error back?
- You may not post replies
- You may not edit your posts
Forum Rules
