Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Running Megatree zig zag starting from the top
    1,173
    Default Re: Running Megatree zig zag starting from the top
    you could do a flat tree. with pixel effects it will be fine and might even improve images.
    Folsom, CA, USA
    1,959
    Iím with Martin...I would add wire, but how many pixels are you doing per string. I did 50 so I could use Pixel connectors to pigtails at top, and pixel connector to pixel connector at the bottom. Arenít you doing 50 per strand too.
    In Lights Therapy
    North Vancouver, BC, Canada
    689
    i would be adding 3" of wire at each leg to reduce rension. pixels hate tension on the wire.
    Couldn't agree more. I guess that is more or less what I should have asked up front. I ended up doing that last year with my mini trees, because I zig zagged, but then when it hit the bottom and had to shift over, the gap wasn't enough. So I Ended up with 8 pixel strings hacked up in 4 places having to splice in 3 wires in each spot to make it work. And work it did, except this year, I'm not using that same mini tree setup, so I'm stuck with a bunch of strings with extra wire I have had to partially remove lol. I guess I was wondering if I should go down that road for the mega tree, if I wanted to run the controller from the deck. Trying to figure out if that was worth it
