Thread: Replacing Incan's on older wireframes
    Jan 2011
    Chili, NY
    51
    Default Replacing Incan's on older wireframes
    I am getting ready for my last season of decorating. I have several wireframes that still have incan minis. I want to replace some of the worn and blown bulbs before I get ready to sell after the season. I have tons of bulbs that I saved from bad strings over the years. Problem is, when I change out the bulb (remove from old socket and put in socket for wireframe string) the bulb blows. What do I need to know about my bulbs so I can get appropriate replacements??
    Serenity prayer for Xmas addicts:
    God, Grant my wife the serenity to accept the things she cannot change
    The courage to ignore my impulse purchases
    And the wisdom to know we need more lights
    Jan 2010
    Omaha, NE
    2,031
    Default Re: Replacing Incan's on older wireframes
    The bulbs must use the same voltage or they will blow or be brighter or dimmer.
    Doug
    Having Fun with Wire Frames and Lights.
    www.wireframedlites.com
    Custom Hand Made In USA
    FaceBook:
    http://www.facebook.com/wireframedlites
    Phillips Family Display
    http://www.facebook.com/phillipsfamilydisplay
    4,137
    Common string sizes are 15 / 30 / 50.
    Putting a bulb from a 50 into a 15 / 30 will burn it out.
    Putting a bulb from a 15 into a 50 will cause it to burn dim.
    100 strings are actually 2 x 50.
