Results 1 to 7 of 7
Thread: FPP Master/Remote Network
    Jan 2014
    40
    Default FPP Master/Remote Network
    I'm looking to confirm my network setup in regards to the FPP Master/Remote config. Is it ok to have the Master communicate via Wifi to the AP and the Remote communicate to the AP via Ethernet. My AP is a UB Loco M2. I want to make sure the sync packets dont have to be on the same network/media.
    1,806
    Default Re: FPP Master/Remote Network
    Your AP is going to be doing "excess" routing but it should work (it is just software after all). Why three different networks?
    Usually the FPP connects to a switch via ethernet and then the controllers and other FPP connect to the same switch. The WiFi of the master is used to connect to your home network so that you can send your sequences to it and manipulate the setup. Why do you want to run the controller directly off FPP?
    Jan 2014
    40
    I want to keep it completely off of my home network and run the sequence from sd card on the FPP locally. To access the FPPs for changes or uploads, I simply connect to the AP from my home computer (I dont need to make many changes). From what I understand the sync traffic between master and remote is nominal. My question is using master to communicate with remove via wifi and ethernet (I assuming the AP will handle any routing).
    4,927
    The master and slave need to be on the same network. Depending on how you configure the AP, The wired and wireless would be the same network. The drawback is a slight delay incurred on the wireless side that may cause the slave to be a bit behind.
    Jan 2014
    40
    So you are recommending this? Master and Remote on same net... AP connected to home router if i want that, or connect to it via wifi too for updates and uploading sequences...
    4,927
    Your picture shows everything on different networks. Assuming you are using a 192.168 net. All of the addresses would start with the same three numbers: 192.168.40.??? giving you 255 devices on the 192.168.40 subnet. Then everything will work and be seperate from your house network.
    Jan 2014
    40
    Ok, I think the missing piece is putting the AP in bridge mode vs router mode, correct? That way everything is on the same subnet... regardless of interface (wlan or eth0)... Ive be operating the AP in router mode, hence the confusion.
