Thread: Problem with display setup in 3.6u2
    Oct 2018
    2
    Default Problem with display setup in 3.6u2
    Just download vixen to 3.6u2 last year used 3.5 u4, While in set up preview, i select an element from the list like ornament, draw the ornament and click ok. It creates ornament 2 or group at the bottom of the list. it changes it on all screens, set up display and sequencer. I've tried this multiple times on different elements, same problem Is this a bug?
    Jul 2015
    Townsville Aus
    62
    Default Re: Problem with display setup in 3.6u2
    I think it is a bit of a bug. But if you are trying to do it as normal with creating the visual element, just hit cancel when the creating part happens in the setup preview. It should then base your drawing on the element selected and not create a new one. I have also noticed that undo does not clear anything until you use the select tool and click on the preview screen again.
    Maryville, Illinois
    1,652
    That is a bug and I have it on my list to look into fixing it. If you select an element in the tree to draw an item in the older manner, it should not prompt with the creation wizard.
