Thread: What are you using for Midi Tree Base Ring
    Colorado Springs
    3,810
    Default What are you using for Midi Tree Base Ring
    I am planning to add a couple of 180 degree Pixel Midi Trees (approx 6' tall) to my display this year, and looking for ideas for a base ring. The soil here is not solid enough for pegs, they would pull right out. Suggestions?
    4,611
    Default Re: What are you using for Midi Tree Base Ring
    I use hula hoops
    1,599
    Maybe a midnight garbage/recycle run?
    I found a ring that would hold a glass patio table in the neighbor's garbage one day. It would work good for a base ring for a midi tree.
