Results 1 to 5 of 5
Thread: DIGWDF Four Stick and Xlights
    Jan 2014
    40
    Default DIGWDF Four Stick and Xlights
    I am trying to see if anyone out there can explain how to use a Four Stick in Xlights? I have the PIC flashed with the DMX code and ESP-01 flashed with the ESPixelStick 3.0 Serial code. My question is in Xlights... How is the controller set up? Like any other E1.31 controller with an IP addr? How do i set it up and with the channels ?
    1,434
    Default Re: DIGWDF Four Stick and Xlights
    Just add a E1.31 controller w/ the Universe #, if Unicast also will need the IP address, and it will only have 4 channels.
    Jan 2014
    40
    in the model, do i need to set the controller to dmx and a channel number?
    9,201
    Quote Originally Posted by gpoduska View Post
    I am not familiar enough with xLights to help with this. I would imagine that because you're sending the data in an E1.31 wireless format, the ESP would decode the data into the desired end-format used in the pic. I would think you'd want to set the channel number to the controller, though. Just a hunch...
    http://digwdf.com/store/
    Jan 2018
    220
    Just set it to start channel. The ESP module is what picks up the signal then translates it. I run renard and dmx from xlights, tget are all just assigned E 1.31 as that it was the esp modules read.
