Results 1 to 6 of 6
Thread: Landscape lighting app
    Tucson AZ
    16
    Default Landscape lighting app
    Is there an app that I could use with a falcon controller for landscape lighting instead of using test mode or a computer? If not, is there a controller out there that would work for landscape lighting? Thanks!
    May 2016
    285
    Default Re: Landscape lighting app
    The Falcon F16v3 can run sequences directly from a micro SD card if the latest version of the firmware is installed. An F16 is overkill for a landscape lighting system, imho.
    Falcon Player (“FPP”), a Raspberry Pi, and a Falcon PiCap together also create an extremely capable “smart pixel” system that can be used for landscape lighting. FPP has a scheduler capable of running multiple sequences at different times of the day/night. This would be my choice unless you’re running more than a couple thousand lights, and will only cost around $70. Or use a Beaglebone Black with one of Dan Kulp’s capes. Same result, but the BBB costs a little more.
    Or do you mean software that will allow you to tell the controller what to do other than run in test mode? If so, that would be Xlights or Vixen?
    Nov 2017
    142
    I use a raspberry pi 3b+ with a pihat in an enclosure on the outside of my house. it's sole function in life is to control my landscape lights. I did a couple of short sequences, one nightly, and a couple of themed ones for holidays and they run on a schedule.
    Tucson AZ
    16
    I was thinking about using the a FPP, but haven’t made one yet. I’m more interested in being able to manipulate the colors from my phone. I might have to look in another direction to accomplish what I want. The only reason I was wondering about falcon is because I have the F4v3. Did this get the software upgrade to use the SD card to run the show?
    May 2016
    285
    The ESPixelStick may be something you would like. When set in test mode, you can can select the color from a full palette on your phone via the web UI. For straight on/off functionality with color variation, that would work just fine.
    Jun 2014
    Springfield, TN
    21
    If you're just looking to manually control the lights with an app you can use SP105E Magic Controller. Very cheap and works pretty well. I use one on my patio.
