Thread: trying to export seqs from Vixen for Falcon player, pop up warning
    Oct 2017
    Buchanan, GA
    325
    Default trying to export seqs from Vixen for Falcon player, pop up warning
    So i decided to try a rasberry pi this year running FPP and using my Vixen seqs, but when i was trying to export i got a pop up message saying
    some of the selected controllers do not support universes.
    these controllers will not be included in the universes file.
    some manual FPP output config will be required.
    is it just saying that cause i have my controllers inside of Vixen picked as DMX open? Do i need to change that to another one if so witch one should i pick?
    FB @ langleylights
    Folsom, CA, USA
    2,077
    Default Re: trying to export seqs from Vixen for Falcon player, pop up warning
    That is not an issue. Just saying it can't include in the universe file, which is imported for easy setup.
    You will just need to manually input that information.
    - likely on FPP Input/output - - Channel Output - - Others.
    Add a DMX-Open controller there and configure
    In Lights Therapy
    Oct 2017
    Buchanan, GA
    325
    Oh, I had planed to do that anyways.
    Thanks for the info. the Pi should be here tomorrow so maybe tomorrow night i can play around with it.
    FB @ langleylights
