Results 1 to 6 of 6
Thread: Bullet to Square not working
    Lombard, IL
    665
    Default Bullet to Square not working
    I am confused. I am replacing my roof line with bullet pixels. I have older square pixels on my verticals. I have already tested, and it worked fine, a run that starts with square pixels then switches to bullet pixels. Basically half of my roof. I am now trying to get the other half to work. This starts with bullet pixels and ends with the square ones. This does not work. The square ones won't work. I've checked the square run by itself and it works fine. I've put extra bullet pixels at the end of the bullet run and they work. I confirmed that the 12v, GND, and Data lines are matched up. It just seems to stop at the transition point. Any suggestions?
    May 2015
    13
    Default Re: Bullet to Square not working
    If both Pixel runs work OK independently then check the end connectors for corrosion, check the end connectors for debris and try a shorter run of fewer pixels to verify the end connectors are OK.
    Anchorage, AK
    347
    Could be an issue with the old timing protocol of the strings versus the new string protocol. It did change about 2 yrs ago. Instead of mixing strings on the same port, does the problem go away with all the same type of pixels on one port?
    4,200
    that protocol change only impacts the first pixel in the chain. After you get through a pixel or two the "idle" time is huge.
    Lombard, IL
    665
    Quote Originally Posted by vwbugjpt View Post
    Connector is not an issue. Have direct wired to single square pixel at end or bullets, no go. Have direct wired left over bullets and they work fine. I don't think run length is an issue. Same controller and PS have had longer runs connected without issues. Current test is 43 Bullet Pixel that are to connect to 17 Square Pixels.
    Lombard, IL
    665
    Update, forget the issue. I flip flopped my verticals side to side. Just to test. That works. It might be something to do with the first Pixel on the one vertical, but if I have it and number one pixel all works fine. You got me, but it's working.
