Results 11 to 13 of 13
Thread: Arduino over lan using vixen
    Southern California
    810
    Default Re: Arduino over lan using vixen
    OK. First I have to ask, are you going to use dimming or just on/off for your arduino lights? I ask because I have two sketches. One for non dimming lights and one that supports dimming lights. The one that supports dimming lights REQUIRES a Zero Cross Detection circuit.
    Kevin
    isle of wight uk
    32
    Hi no dimming is involved, it will just be used to turn the lights on and off,
    thanks pete
    Southern California
    810
    Quote Originally Posted by littlepete83 View Post
    thanks pete
    OK. look at this thread, http://doityourselfchristmas.com/for...m-ESPixelstick, and try the code listed.
    You would first need to purchase an ESP-01 and connect it to your Arduino MEGA and configure it for your wifi network and select the output as Renard protocol. There are other threads explaining the setup of the ESP-01. If you need me to point you to one, let me know. Since you are already using e1.31 devices, I assume you know how to set up the ip addresses and setup the output of the Vixen program.
    Kevin
