Results 1 to 10 of 15
Thread: Esp GPIO
    6,560
    Default Esp GPIO
    Does anyone have the secret code to invert the pins from active high to active low and vise versa ?
    I see that the dumb rgb can be controlled directly but unfortunately they are off while data and on while no data .
    4,417
    Default Re: Esp GPIO
    It depends on the build environment. Are you using Arduino?
    In Arduino you have to manually define on and off as needed for your project.
    #define ON LOW
    #define OFF HIGH
    Then use:
    digitalWrite(PinId, ON);
    digitalWrite(PinId, OFF);
    6,560
    Hi Martin
    Thanks for your reply .I have tried a few ways with your suggested method
    and only achieved turning the leds of completely.
    How would I incorporate the on off into this ?
    digitalWrite(input_1_blue, e131.data[channel_1_blue]);
    I may just have to be content with reverse sequencing lmao.
    1,380
    There are two ways to invert if not doing simple on off. say you have an unsigned int in the range 0- 255. simple inversion is 255 - x. a more complex inversion can be done with map described https://www.arduino.cc/reference/en/...ions/math/map/
    6,560
    Thanks Mike . I have tried everything to avoid extra parts but I think the only way is to use the mosfet circuit .
    Best I can get without the extras is reverse sequencing and only have on / off control . The downer with it is the lights would be continually on once the sequence ended but then again it is only for 7 pairs of eyes .
    4,417
    becomes
    digitalWrite(input_1_blue, (0 == e131.data[channel_1_blue]) ? OFF : ON));
    But this just gives you on or off. If you want to dim, then you need to generate a PWM signal which is very different.
    4,417
    If you want to dim then you need to use a PWM channel. For a PWM channel you use the inversion example: PwmAccessMethod(id, value) where value = 0^InputDataFromE131 (^ == xor)
    Huntsville, AL
    3,648
    becomes
    Martin: Your suggestion would be correct without the "0 == "
    As posted the instruction says if Value is == 0 (this is a TRUE) hence return/use OFF ... which is not what you wanted
    Correct way and uses less bytes in instruction:
    digitalWrite(input_1_blue, (e131.data[channel_1_blue]) ? OFF : ON));
    Now -- if e131.data[channel_1_blue is NON-Zero the value used is OFF whixh is the reversal you are attempting to get.
    My suggestion:
    #define Bit_Reversal(V) (V ? 0 : 1)
    now the example
    digitalWrite(input_1_blue, Bit_Reversal(e131.data[channel_1_blue]));
    Not to be picky.
    Joe
    6,560
    Quote Originally Posted by martinmueller2003 View Post
    if you want to dim then you need to use a pwm channel. For a pwm channel you use the inversion example: Pwmaccessmethod(id, value) where value = 0^inputdatafrome131 (^ == xor)
    thank you
    6,560
    Firstly my apology for asking a question and providing wrong data .
    digitalWrite(input_1_blue, e131.data[channel_1_blue]); <<< should have been
    analogWrite(output_1_blue, e131.data[channel_1_blue]);
    Your willingness to help is unprecedented so Thanks very much for your detailed replies.
    Both solutions worked for different Write methods and my brain grew 3 sizes today lol
    Joe's solution gave a cleancut digital solution and that was mistakenly my fault in the example I posted
    Martin nailed it with this thanks for the push in the right direction
    Analog blinded me to the actual issue .
    Woot now have direct control and dimming of RGB !!!!!
    Thanks much
