Results 1 to 4 of 4
Thread: Help!
    Dec 2018
    16
    Default Help!
    I just updated to the S5 Showtime Software Suite from Light-O-Rama and I can't get it to control lights. The hardware utility will recognize and let me configure the controllers but the sequencer and when I run a show will not output to the lights. I can't find the "control lights" option in the sequencer either. Any ideas?
    Jan 2010
    Omaha, NE
    2,023
    Default Re: Help!
    You will get better help here. http://forums.lightorama.com
    Doug
    Having Fun with Wire Frames and Lights.
    www.wireframedlites.com
    Custom Hand Made In USA
    FaceBook:
    http://www.facebook.com/wireframedlites
    Phillips Family Display
    http://www.facebook.com/phillipsfamilydisplay
    Jan 2018
    Saratoga Springs, UT
    43
    Default Re: Help!
    There should be a tab just right of the preview window that says "control lights." Make sure the box is checked when you open it. Depending on your set up, the Comm Listener should be running as well.
    Dec 2018
    16
    Default Re: Help!
    Thanks, it worked!
