Results 31 to 38 of 38
Thread: Vixen is working on back up PC, can't get the PC to talk to box and lights... been to
  1. #31
    Oct 2017
    Buchanan, GA
    325
    Default Re: Vixen is working on back up PC, can't get the PC to talk to box and lights... bee
    Ok, a couple things. The success message was not there, so something went wrong. There is a setup screen now if you select the controller and hit the gear icon in Display setup. ensure your device is selected in the the drop down and try again. If it still does not work, then provide the info and error logs.
    it was already picked. and nothing else there to pick from.
    At least this version seems to be opening and closing properly. at least so far.
    09/15/2019 22:13:41.780 [VixenModules.Controller.OpenDMX.OpenDmx] Error opening the OpenDMX device 0 : FT_DEVICE_NOT_FOUND
    09/15/2019 22:13:41.780 [Vixen.Sys.Managers.OutputDeviceExecution`1] Error starting device DMX Open System.Exception: Failed to open OpenDMX device. Error from Driver: FT_DEVICE_NOT_FOUND
    at VixenModules.Controller.OpenDMX.OpenDmx.Start()
    at Vixen.Sys.Output.BasicOutputModuleExecutionControl .Start()
    at Vixen.Sys.Output.OutputController.Start()
    at Vixen.Sys.Managers.HardwareUpdateThread.Start()
    at Vixen.Sys.Managers.OutputDeviceExecution`1._StartD evice(T outputDevice)
    at Vixen.Sys.Managers.OutputDeviceExecution`1._Start( T outputDevice) at VixenModules.Controller.OpenDMX.OpenDmx.Start()
    09/15/2019 22:28:09.306 [Vixen.Sys.Managers.OutputDeviceExecution`1] Error trying to stop device DMX Open System.TimeoutException: Controller DMX Open failed to stop in the required amount of time.
    at Vixen.Sys.Managers.HardwareUpdateThread.WaitForFin ish()
    at Vixen.Sys.Managers.OutputDeviceExecution`1._StopDe vice(T outputDevice)
    at Vixen.Sys.Managers.OutputDeviceExecution`1._Stop(T outputDevice) at Vixen.Sys.Managers.HardwareUpdateThread.WaitForFin ish()
    09/15/2019 22:46:09.186 [VixenModules.Controller.OpenDMX.OpenDmx] Error opening the OpenDMX device 0 : FT_DEVICE_NOT_FOUND
    09/15/2019 22:46:09.186 [Vixen.Sys.Managers.OutputDeviceExecution`1] Error starting device DMX Open System.Exception: Failed to open OpenDMX device. Error from Driver: FT_DEVICE_NOT_FOUND
    FB @ langleylights
  2. #32
    Maryville, Illinois
    1,665
    It looks like it is not finding the device by it's index which is interesting if it was in the list to pick. That device not found is being reported by the FTDI driver. I am going to add a bit more logging and make one other change, but this is very weird.
  3. #33
    Oct 2017
    Buchanan, GA
    325
    im having terrible luck this year.
    FB @ langleylights
  4. #34
    Maryville, Illinois
    1,665
    Let's give build #904 a try. I would like to see the error and the info logs after you try it to see all the info related to it.
  5. #35
    Oct 2017
    Buchanan, GA
    325
    okay so the latest vixen i had been using had been working great for making my Seqs and all I got my rasberry pi working and got the seqs converted over to use with the FPP on the pi. i closed vixen lastnight when i went to bed and today when i went to use it im getting the error i used to get again.. why is this? its been opening working not giving the (not responding errors) and closing just fine now it wont open
    FB @ langleylights
  6. #36
    1,474
    Look for a ".lock" file in your profile directory and delete it.
    Sent from my ASUS_A009 using Tapatalk
  7. #37
    9,215
    I'll also suggest that if you're using Windows 10, turn off User Account Control. It can easily cause some weird, unexpected things involving temporary files that should be erased upon closing an app, but they remain because UAC blocks the deletion....
    http://digwdf.com/store/
  8. #38
    Oct 2017
    Buchanan, GA
    325
    Windows 7. I tried to find the file and no luck.. i ran a search and no luck.
    FB @ langleylights
