Results 1 to 10 of 13
Thread: Window frames
    Sep 2017
    11
    Default Window frames
    I've made window frames out of PVC for all my windows but am struggling with this window. I use J channel to hang it but unless I can figure out a way to connect that angle up top I'm lost. I need some form of a bendable connector. Thoughts?
    Sent from my SM-G960U using Tapatalk
    Nov 2015
    Covington, WA
    41
    Default Re: Window frames
    Maybe gentle application of a ton of heat and bend it? It doesn't need to pass wires internally. Actually with the 90 on there, you only need a small bend so easy peasy.
    1,426
    Insert the pipe into the 90 elbow and using a heat gun, heat the PVC and bend it to the desired angle. Of course I think I would start at the left side, doing the same thing, as it is a greater angle, then as you bend the pipe down from the right you can connected it into the left side to hold the angle.
    May 2016
    258
    Duct tape and paint it white, or use athletic tape. People are looking at the lights, not how perfect your frames are. They do have some bendy pvc connectors, but I donít know if they can bend like you need.
    Jan 2010
    Omaha, NE
    2,029
    Just flatten the ends of the 2 pieces of PVC pipe and screw them together for the one on the left side.
    Doug
    Having Fun with Wire Frames and Lights.
    www.wireframedlites.com
    Custom Hand Made In USA
    FaceBook:
    http://www.facebook.com/wireframedlites
    Phillips Family Display
    http://www.facebook.com/phillipsfamilydisplay
    Dec 2018
    48
    heat up sand in the oven, cap one end of the pvc and fill the pvc with the heated sand. Give it a few minutes and the pvc will bend any way you want.
    Moline, IL
    65
    Just curious, you said you were using J-channel to hang them, have you considered using the J-channel to hold the pixels instead? I think it would be easier to cut to shape and you might be able to use Velcro strips to hold them in place since that looks like it might be hard to get in there properly with a drill.
    Mar 2015
    116
    I had great luck last year just using my heat gun on PVC to bend pieces I needed.
    Jan 2010
    Mims, Fl
    686
    without seeing the rest of the windows, the other frames look square. Would it look uniform to leave the top triangle out?
    Staten Island New York
    285
    I was thinking the same thing. Even from a sequencing point of view it would look more uniform having them all the same shape.
