Results 1 to 10 of 12
Thread: What Mp3 board are you using .
    6,253
    Default What Mp3 board are you using .
    This has probably been asked numerous times before but I thought I would see what folks are currently using .
    There seems to be a wide variety available both in capabilities , support and price range .
    I have found one really cheap without support and one that seems common .
    Any suggestions ?
    Cheap
    http://www.mdfly.com/products/sd-car...rs232-ttl.html
    4,137
    Default Re: What Mp3 board are you using .
    I would guess that most of us do not use such a device. The show players tend to have built in MP3/MP4 decoding. Some of us that use things like a raspberry PI as a show player also add an external audio DAC / amplifier. The reason for this is that the player needs to keep the audio and the lighting in sync. Using a stand alone player (such as the ones you identified) typically results in independant audio / lights which, for many of us, is not the goal.
    6,253
    Thank you for your reply Martin .
    Sorry , I should have been a little more specific . The mp3 player will not be used for show sequence , but for embedding in a prop that is independent and will only play when triggered .
    Aug 2007
    MD, USA
    1,108
    I had a lot of issues with the MDfly and had to abandon it for my Holiday Hotline project. I switched to the one in the link below and really like it for Android. I am using it again this year for my singing skulls.
    https://www.dfrobot.com/product-1121.html
    ~Jason
    [URL]http://www.tooz.us[/URL]
    6,253
    Quote Originally Posted by toozie21 View Post
    I went ahead and ordered 10 of them here
    Aug 2007
    MD, USA
    1,108
    Good call. I probably bought mine on eBay, but that was the link I had on my webpage for the Holiday Hotline, so I pasted it.
    ~Jason
    May 2016
    284
    I picked up a few of the MDfly AU5017 boards a couple years ago for Halloween projects. The main issue was figuring out the hex codes to control it and build it into an Arduino sketch. They’re not well-documented. I think I posted sample code on hauntforum in the techno terror area.
    But Inagree they’re not the easiest to integrate into a project.
    6,253
    I could get them locally but their 3200 % markup seems a little steep .
    6,253
    I received a few of these today .
    They are easy enough to load audio tracks ,even easier than using an a sd . Unfortunately they did not have documentation.
    I am assuming the I/O trigger pins are gnd switching as far as I can tell from what the notation on their web site states .
    6,253
    Well I found some Documentation on this board and managed to get it working ! huha .
    What a treat to see this all come together . Using only 5 pins on the wemos and having 3 yet available .
