Results 1 to 6 of 6
Thread: Servo tip for beginners
    6,080
    Default Servo tip for beginners
    Buy good quality servos ! The difference is night and day between the medal and plastic geared models .
    All may seem fine with the plastic servos until they actually get used in a prop . You can waste a lot of time messing with code settings and just getting frustrated . Settings adjustments can smooth out some things but not all and definitely nothing like replacing the servo with quality . The old saying holds true .
    You gets whats you pays for !
    Give a listen to this servo compared to the plastic servo I used in the skull .
    SLC, UT
    937
    Default Re: Servo tip for beginners
    I'm looking at getting started in servo props this year. Can you give some suggestions of good servos to purchase?
    6,080
    These are 2 types I have tested so far .
    MG996R Metal Gear Torque Digital Servo >> Quite heavy duty
    MG90S Metal Geared Micro Servo >>> much better than the SG90 but still for light duty
    SLC, UT
    937
    Thanks for the suggestions.
    6,080
    I just ordered a couple of these for heavier lifting .I hope I don't need to go even larger than these .
    Moving a wolf's head forward and back for a servo is tougher than I imagined .
    ANNIMOS 25kg DS3225MG Digital Servo
    6,080
    Premium and real strong , best yet and has metal arm/horn .
