Results 1 to 1 of 1
Thread: Renard ESP Flasher help
    Jan 2019
    33
    Default Renard ESP Flasher help
    ordered and built the REEFer flasher started reading tutorial and says I need the 3.3v and it is selected by a switch, however the usb dongle received is solid soldered on the 5v setting. Am I to remove this solder and resolder on the 3.3 setting or is this tutorial out dated and I am missing something
    Update: moved past voltage installed java and installed CH340G drivers, well attempted all I get is driver install failure... tried java tool I get JNI error check installation. I am batting 1000 here
