Page 3 of 15 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 149
Thread: Pixelpops/stick wifi module question (esp8266 esp-01)
    1,542
    Default Re: Pixelpops/stick wifi module question (esp8266 esp-01)
    There is already an "ESPArtStick", that is using a Wemos and the ESPixelStick firmware
    North Vancouver, BC, Canada
    993
    Does anyone have any pictures of what the pixel stick with the wemos module instead looks like?
    4,470
    The ESPArtStick site has pictures.
    https://espartstick.ecwid.com/ESP-Ar...ete-p143798032
    993
    Sorry, I thought that was a special made board in that case. I was still picturing the original pixel stick that is detailed in the thread/wiki on this site. People are saying oh just switch to this other module, but I still pictured everything else mostly the same. So would that whole build guide be mostly scrapped if swapping away from the esp-01?
    4,470
    If you use the existing PixelStick carrying board and replace the ESP01 with the WeMos board then you need to solder 6 wires from the 6 pin connector on the base card and solder then to the WeMo board. I personally would hand craft a ribbon cable to do this job but that is the extent of the customization needed.
    Folsom, CA, USA
    2,162
    The ESPArtStick is only 5V. 12V folks will need to buck power for WeMOS, and power inject lights
    With the WeMos breadboard, I have added terminal boards to the WeMos and replace the ESPixelStick.
    In Lights Therapy
    4,470
    The ESPArtStick page had two versions. One for 5V and one for 12V.
    https://espartstick.ecwid.com/ESP-Ar...ete-p145284289
    Folsom, CA, USA
    2,162
    12V page hmmm... Missed that
    With the WeMos breadboard, I have added terminal boards to the WeMos and replace the ESPixelStick entirely
    This was 5V. Add a couple components And do the same with 12v
    This little WeMos (with Shelby’s firmware) can replace most all the ESP-01 design devices. It also includes a built-in programmer with an on board micro USB port.
    I don’t see any data buffering, so distance to first pixel may be limited - only tested about 6 feet.
    In Lights Therapy
    993
    Don't worry, as did I haha
    993
    That's it!? Literally everything is the same except you have to solder 6 pins between the wemos and the board??? That's great!! I'm kind of wondering, with how popular the pixelstick project was (is) in the community, I am quite surprised to not have seen anybody do an update/how-to for the wemo variant. Unless it's just buried in the almost 60 page thread and I missed it. Is there any parts that aren't needed or need to be added to the BOM ? Other than potentially needing a buck converter for 12v?
