Page 1 of 15 12311 ... LastLast
Results 1 to 10 of 149
Thread: Pixelpops/stick wifi module question (esp8266 esp-01)
    North Vancouver, BC, Canada
    1,007
    Default Pixelpops/stick wifi module question (esp8266 esp-01)
    Just starting to brainstorm for this year's display during the end of my "off season"/break. One of the things I had been interested in looking into, was using/building some pixelpops/espixelsticks. Now I've found some of the resources about the BOM and build instructions, so I have a rough idea. But one thing keeps returning to me about the wifi modules used (I believe ESP8266 ESP-01), and I can't recall the specifics. I seem to remember reading something about a problem with some of these depending on the source. As in, you could get the same part number from two different sources, and one would be fine, and the other unusable. Maybe something about how you couldn't program one kind properly? Either way, I'm trying to figure out how to tell which modules are ok for this purpose, or what makes some of them unuseable. I found a listing here for example, and trying to figure out if these would be fine https://www.aliexpress.com/item/32341788594.html
    1,436
    Default Re: Pixelpops/stick wifi module question (esp8266 esp-01)
    One of the issues is with modules that use PUYA chips. It doesn't appear that the linked ones do. The PUYA chips need a fix to the code that will properly write the data to them or they "forget" what was written.
    Those also say in the Q&A that they are 512KB boards. Someone can correct me but I think the current standard board is the 1MB board. Also not sure if it matters for the current pixel code.
    1,007
    I have to be honest, I didn't actually fully review that item listing. I just liked the price and needed an example of the module for the post. Dang....I can do all this kind of work if I have guidance, but I'm no electrical engineer. Didn't even occur to me that the exact part number listed in the BOM guides would have variants to the capacity. I thought that WAS what the part number was for. Getting the correct config. Thanks for the quick response Mike. So as far as you can tell, unless there is an issue with the 512KB capacity as per someone letting me know here, the PUYA chip was the main issue I was vaguely remembering, and these are not some of those?
    4,481
    FYI: Last time I checked the code was big enough that if you used the 512KB version the Over-The-Air update would not have enough space to work properly. I would not purchase the 512KB version ESP01. If I remember correctly, the board color was changed when they went from 512KB to 1MB. I think the 1MB devices have a black PCB. The PUYA chip is a bit more difficult to detect.
    1,007
    Damn! Anybody have or know of a good, reasonably priced source for the proper ESP-01 modules?
    1,436
    I do not have personal experience with this company but they understand the puya problem and proactively check
    https://www.addicore.com/ESP8266-ESP-01-p/130.htm
    Someone from their company has been on the forums occassionally as well. $4 is not <$2 but unless you are doing a ton of boards, it is probably ok.
    1,007
    Thanks for that Mike. I will likely give them a shot. And as I'm writing this, came across this source https://www.aliexpress.com/item/3227...chweb201603_53
    Assuming the pic isn't just a stock picture, black board, which as mentioned above may indicate the 1mb variant. Any feedback on that one from anyone? $4 USD is roughy $5.35 Canadian (assuming you didn't get marked up or squeezed by the exchanger...hahahahahaha....that's a good one). $5.35 VS $1.52 isn't insignificant when you factor the costs of building maybe 10 of the units. But on the flip side, at least Addicore openly confirms they aren't PUYA chips...If the PUYA chips have such an issue with being programmed, how is it that it's such a toss up as to whether your still getting a (as far as I understand the problem) faulty part?
    1,007
    Just tried to build a new BOM for this (minus the ESP-01 module). How does this look? https://octopart.com/bom-tool/sOzWBJ74
    Folsom, CA, USA
    2,164
    I'm doing away with ESP-01 and it issues…..moving to WeMos D1 Mini V3's - For the 5V folks, just add a development board and a few jumpers you have a ESPixelDevice with a built in programmer. If you are a 12V person add an addition buck device or LM1205.
    Below is my thoughts for a design . prototype sketch and some components. Fuse is a resettable. Terminal boards were 3.5 pitch bent to mount in 2.41 holes.
    I tested to 800 PixaBulbs - Wifi distance was only tested to 30 feet, but it is an ESP based unit so should be the same as ESP-01.
    https://www.aliexpress.com/item/3304...c00DzzRmq&mp=1
    https://www.aliexpress.com/item/3280...170a4c4dZ37Yxn
    https://www.ebay.com/itm/Mini-DC-DC-...53.m2749.l2649
    I need a volunteer to help me build and order a circuit board
    Edit: hoping Shelby's V3 will incorporate the WeMos
    In Lights Therapy
    6,628
    +1 on the Wemos
    More i/o .
