Page 3 of 27 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 262
Thread: FPP PB16 Pixel Controller
    Grand Rapids, MI
    45
    Default Re: FPP PB16 Pixel Controller
    I guess I forgot to put it in the manual but it is a requirement to get blue PCB's.
    What WIFI adapter are you using? I cannot get any of mine to work with FPP 3.2.
    Quote Originally Posted by Supergumby View Post
    Kudos Scott.
    The boards came today and I put one together, they are very easy to assemble and well laid out. Easy to configure.
    Now to connect some strings and see how the whole FPP master / slave setup is going to work for me.
    Thanks again for all of your hard work and your willingness to share.
    Don
    Attachment 41729
    Scott H.
    Mar 2010
    32
    Quote Originally Posted by scooter_seh View Post
    That's funny, I actually meant to get blue PCBs but I forgot to select it until after I had started checkout. The WiFi adapter is a RealTek ( I got it HERE).
    Jan 2018
    254
    Ok, so if I am going to connect this to a router, and send it information via ethernet, do I still need to pocket beagle?
    Aug 2012
    Nova Scotia, Canada
    1,793
    The pocket beagle is the "brains" of the board, the board is built around it.
    FPP would use it as a remote and have all your sequences uploaded onto the sdcard for playback locally from the pocket beagle. Wifi would only be used to sync the packets and to administer the board (upload sequences).
    Not sure if you could use a USB to RJ45 and run it as a stand alone E131 controller???
    Grand Rapids, MI
    45
    You need a USB to Ethernet adapter or Wifi adapter to connect the controller to your network. Then it can be run in Master or Remote or Bridge mode.
    Scott H.
    Jan 2018
    254
    Ok, so hardwired to my network, then I wont need the pocket beagle.
    Framingham, MA
    517
    For this board, the PocketBeagle is ALWAYS required. Without it, it will do nothing. The PB is the main/only processor that handles pretty much everything.
    Dan Kulp
    Framingham, MA
    517
    What adapters are you trying? Any of the "150MB" and "300MB" 2.4ghz only adapters should work fine. Anything other that is likely very hit or miss. You can try turning on the Kernel drivers which may allow more of them to work.
    If you can determine which chip they use, (lsusb -v and the lookup the vendor/product id's) let me know and I can try and see if a driver can be added. Some are fairly easy to get working if I can find a driver. It just takes a bunch of time to build the drivers.
    Dan Kulp
    Grand Rapids, MI
    45
    I was trying an edimax the other day and it wasn't working but today it is working. I guess it was an user error.
    Scott H.
    Aug 2012
    Nova Scotia, Canada
    1,793
    I just ordered 5 boards from JLCPCB, I probably won't be using them this year but will definitely test in February.
    Now to ask Santa and family for Amazon gift cards this Xmas so I can get a few Pocket Beagle's! LOL
    Thanks for the design Scott! and a big thanks to Dan for supporting the beagles in FPP.
    I find it unbelievable there are still guys that contribute so openly and freely to the community! You guys rock!
