Page 19 of 21 FirstFirst ... 91718192021 LastLast
Results 181 to 190 of 208
Thread: FPP PB16 Pixel Controller
  1. #181
    Delaware, OH
    4,364
    Default Re: FPP PB16 Pixel Controller
    EXCELLENT !
    Thanks for the regen.
    Quote Originally Posted by Supergumby View Post
    Looking at the Schematic, resistors R1,2,and 3 are clearly 120 Ohm.
    It appears the BOM in the root is an older version - regenerating the BOM from current PB16 files lists these as 120's, making the PCB silkscreen correct.
    /Don
    Attachment 42759
  2. #182
    Grand Rapids, MI
    36
    When I first designed the PCB I used 220 ohms. I don't really know why, I choose that value, I think I just misread the internet. I then found out later that 120 ohms is the optimal value. I updated the PCB, and I forgot to fix the BOM. 220 ohm is close enough that you probably won't have an issue if you use it (all 5 my PCB's have 220).
    Scott H.
  3. #183
    Dec 2019
    97
    Quote Originally Posted by scooter_seh View Post
    Those particular resistors are for the 2 dmx/serial outputs, right?
  4. #184
    Mar 2010
    32
    Quote Originally Posted by Glycerine View Post
    R3 appears to be a ballast resistor for the 5 volt power LED.
    R1 and R2 look to be terminating resistors for the RS485 (DMX) lines to prevent data loss from reflection, there's a great tutorial on reflection in a differential bus HERE
  5. #185
    Dec 2019
    97
    Ok, cool. Thanks. I'm just thinking that I will never use the DMX on my controllers anyway, so I'm not too worried about swapping out resistors right now.
  6. #186
    Dec 2019
    97
    One more quick question. Can I expect to be able to run 700/1400 pixels on each port of the diff receivers as well?
  7. #187
    Grand Rapids, MI
    36
    Yes
    Scott H.
  8. #188
    Dec 2019
    97
    Yes
    Thanks!
  9. #189
    Dec 2019
    97
    Me again. I'm working on soldering up a multi out expansion board, V2. This may have already been discussed, but for the expansion header, I think the silkscreen is incorrect. Mine shows that the header notch should face up, but I'm thinking it should face down?
  10. #190
    Nov 2018
    Houston, Texas
    1,171
    This might be what your referring to
