Page 23 of 23 FirstFirst ... 13212223
Results 221 to 226 of 226
Thread: FPP PB16 Pixel Controller
  1. #221
    Dec 2019
    112
    Default Re: FPP PB16 Pixel Controller
    As the person that painted the power leds on his buck converters black because they made to much light, is there a way to turn off that huge power led?
    Should just be able to remove it from the board. Or not solder it on in the first place if building from scratch. Or you could look for some with a smaller light output if they're too bright for you.
    Oh yeah, like uke said, you wouldn't need the resistors either.
  2. #222
    Delaware, OH
    4,382
    Exactly right.
    If you look you will always see a status LED to be paired with a dropping resistor to bring down the current so the led doesn't burn out.
    These can be omitted in almost all cases or replaced with a led that has a lower lumen rating.
    This is true of almost all boards you encounter.
    Quote Originally Posted by Glycerine View Post
  3. #223
    Jan 2014
    85
    Wow! Very cool. Thank you for your efforts into this.
  4. #224
    Feb 2017
    Ohio
    32
    My boards arrived today. Can't wait to get ahold of all the components.
    Anyone happen to build the BOMS from Arrow.com that they would be willing to share.
    Shawn
  5. #225
    Mar 2015
    Bloomingdale Ga
    168
    Quote Originally Posted by sctwohig View Post
    Shawn
    I did not have much luck finding what I needed with Arrow. If you have 2 month to wait until parts arrive, you can find most of it on Alli Express and save alot of money. I did order 1 BOM from Digikey ( minus what I already had) and it arrived within the week minus some resistor arrays that were backordered and came in a month or so later. This was also back in February or late January when things were failing apart overseas. Good luck!
    Sent from my SM-A505U using Tapatalk
    Rayhjr I Love This Stuff!
  6. #226
    Nov 2009
    Monroe, Ohio
    32
    I had to source from Arrow, Tayda, and Digikey. Once it comes in and I can verify I will be glad to share.
