Results 1 to 2 of 2
Thread: Corro Mini Light questions
    Nov 2018
    Fairfax, Virginia
    68
    Default Corro Mini Light questions
    What do you all use to punch holes in your corro and what is the best method for installing mini lights in corro?
    I am planning to use black sheets of corro within a wooden frame to create a life sized light up singing Chewbacca. I figure I will build out a 7 foot tall rectangle box with corro stapled to the frame and enclose the back to keep extra lights used for the mouths from bleeding. What am I missing and what issues am I not anticipating?
    1,522
    Default Re: Corro Mini Light questions
    That is exactly how I made my Singing Snowman, worked great. I just used an old soldering iron, just a cheap pencil one. The tip is the perfect size for minilights. Just make sure you are in a well ventilated area while you are making the holes.
    Guess the only issue I had was where to store my 2 4'x7' props
