Results 1 to 5 of 5
Thread: Help running with Arduino mega
    Sep 2016
    12
    Default Help running with Arduino mega
    I am new to all this do hoping some one can help me out. When I start running vixen all my lights / relays stay on and vixen turns them off. I think the problem is one of my values are flipped. 0-255 instead of 255 -0 somewhere.
    The Problem: I want my lights / relays to be off until vixen turns them on. current status is on and vixen turns them off
    Build info: Mega 2560 using outputs 22 to 53
    4 banks of 8 solid state relays
    ( Just looking for on/off so should be fine )
    Code
    * This code was put together to run Arduino Mega 2650 with Vixen 3
    * Connect Arduino to PC via USB
    * David (DaVaR) Sargent
    * http://www.village4christmas.com/
    * http://www.christmaslighthunt.com/
    * Special Thanks to the following people who guided me to build this code.
    * -Scott Shaver @
    * http://doityourselfchristmas.com/for...el-Relay-Board
    * -wirenut1980@
    * http://www.instructables.com/id/Ardu...-arduino-code/
    * NOTE * The PWM values that need to be sent to the relay board are reversed from the
    * values comming in from Vixen. Vixen 0-255 (off-on), Relays 255-0 (off-on)
    // Define which pins control which channels with Vixen 3 and Arduino Mega
    #define CHAN01 22
    #define CHAN02 23
    #define CHAN03 24
    #define CHAN04 25
    #define CHAN05 26
    #define CHAN06 27
    #define CHAN07 28
    #define CHAN08 29
    #define CHAN09 30
    #define CHAN10 31
    #define CHAN11 32
    #define CHAN12 33
    #define CHAN13 34
    #define CHAN14 35
    #define CHAN15 36
    #define CHAN16 37
    #define CHAN17 38
    #define CHAN18 39
    #define CHAN19 40
    #define CHAN20 41
    #define CHAN21 42
    #define CHAN22 43
    #define CHAN23 44
    #define CHAN24 45
    #define CHAN25 46
    #define CHAN26 47
    #define CHAN27 48
    #define CHAN28 49
    #define CHAN29 50
    #define CHAN30 51
    #define CHAN31 52
    #define CHAN32 53
    int channels[] = {CHAN01,CHAN02,CHAN03,CHAN04,CHAN05,CHAN06,CHAN07, CHAN08,CHAN09,
    CHAN10,CHAN11,CHAN12,CHAN13,CHAN14,CHAN15,CHAN16,C HAN17,CHAN18,CHAN19,CHAN20,
    CHAN21,CHAN22,CHAN23,CHAN24,CHAN25,CHAN26,CHAN27,C HAN28,CHAN29,CHAN30,CHAN31,CHAN32};
    // Total Channel Count
    #define CHANNEL_COUNT 32
    // Serial Speed
    #define PC_COM_SPEED 9600
    int i = 0;
    int incomingByte[CHANNEL_COUNT];
    void setup()
    Serial.begin(PC_COM_SPEED);
    // Set the channel pins to output mode
    for(int channelIndex=0;channelIndex<CHANNEL_COUNT;channelI ndex++){
    pinMode(channels[channelIndex],OUTPUT);
    powerOnSelfTest();
    void loop()
    if (Serial.available() >= CHANNEL_COUNT)
    for (int i=0; i<CHANNEL_COUNT; i++)
    digitalWrite(CHAN01, incomingByte[0]);
    digitalWrite(CHAN02, incomingByte[1]);
    digitalWrite(CHAN03, incomingByte[2]);
    digitalWrite(CHAN04, incomingByte[3]);
    digitalWrite(CHAN05, incomingByte[4]);
    digitalWrite(CHAN06, incomingByte[5]);
    digitalWrite(CHAN07, incomingByte[6]);
    digitalWrite(CHAN08, incomingByte[7]);
    digitalWrite(CHAN09, incomingByte[8]);
    digitalWrite(CHAN10, incomingByte[9]);
    digitalWrite(CHAN11, incomingByte[10]);
    digitalWrite(CHAN12, incomingByte[11]);
    digitalWrite(CHAN13, incomingByte[12]);
    digitalWrite(CHAN14, incomingByte[13]);
    digitalWrite(CHAN15, incomingByte[14]);
    digitalWrite(CHAN16, incomingByte[15]);
    digitalWrite(CHAN17, incomingByte[16]);
    digitalWrite(CHAN18, incomingByte[17]);
    digitalWrite(CHAN19, incomingByte[18]);
    digitalWrite(CHAN20, incomingByte[19]);
    digitalWrite(CHAN21, incomingByte[20]);
    digitalWrite(CHAN22, incomingByte[21]);
    digitalWrite(CHAN23, incomingByte[22]);
    digitalWrite(CHAN24, incomingByte[23]);
    digitalWrite(CHAN25, incomingByte[24]);
    digitalWrite(CHAN26, incomingByte[25]);
    digitalWrite(CHAN27, incomingByte[26]);
    digitalWrite(CHAN28, incomingByte[27]);
    digitalWrite(CHAN29, incomingByte[28]);
    digitalWrite(CHAN30, incomingByte[29]);
    digitalWrite(CHAN31, incomingByte[30]);
    digitalWrite(CHAN32, incomingByte[31]);
    void powerOnSelfTest()
    Serial.println("Power on self test running.");
    Serial.print("Channel: ");
    Serial.println(channelIndex+1,DEC);
    analogWrite(channels[channelIndex], 255); // Turn ON relays one channel at a time
    delay(100); // Wait .1 seconds
    analogWrite(channels[channelIndex], 0);
    turnAllLightsOn();
    delay(1000);
    turnAllLightsOff();
    delay(1000);
    turnAllLightsOn();
    delay(2000);
    turnAllLightsOff();
    void turnAllLightsOn()
    // Turn all Channels ON
    void turnAllLightsOff()
    // Turn all Channels OFF
    South Carolina
    102
    Default Re: Help running with Arduino mega
    dont know if it helps but this is the sketch i use and i have no problems http://doityourselfchristmas.com/for...th-Random-mode
    Southern California
    922
    Look up the "MAP" function. You will likely need to insert it after the " incomingByte[i] = Serial.read();" and before the "digitalWrite(CHAN01, incomingByte[0]);"
    Kevin
    Sep 2016
    12
    Quote Originally Posted by perfection322008 View Post
    that code would not work for me would do not read from vixen.
    Southern California
    922
    Quote Originally Posted by phil_one View Post
    That code has worked for many, many people on this forum. If you need to talk to someone to help walk you through getting it to work, let me know. I have talked to and helped a couple of people with this code.
    To get it to read from Vixen, you have to setup Vixen to send a header that includes the symbols "~!".
    Kevin
