Results 1 to 7 of 7
Thread: Can't get my P 10 panels to run
    Mar 2018
    36
    Default Can't get my P 10 panels to run
    Ok so here is my issue: I have BBB with the octoscroller, I got FPP installed with out to much of an issue. I can get the panels to work using the test mode in FPP but I can't get them to work using Xlights. I have it set it up in Bridge mode to run directly from Xlights because I want to test different effects and experiment. I know it's some sort of set up problem either with Xlights, FPP or both and I have tried several ways including using null channels but this has me banging my head on my desk! Here's some screen shots: Universes 57-68 are what I'm trying to use
    Any help is greatly appreciated
    Folsom, CA, USA
    2,150
    Default Re: Can't get my P 10 panels to run
    You have Universe Count error. This is the total universe of the line input, so yours would be 12 and you would delete line 2 thru 12. that would cover universes 57 thru 68
    In Lights Therapy
    Mar 2018
    36
    ok I will give that a try
    Mar 2018
    36
    So I deleted lines 2 - 12 on both the input and output channels and I still have nothing
    1,539
    You don't need the E1.31 output channels, the Output is the LED Panels, so disable them and delete all of them. And you need to set the start channel for the LED Panels to 1, that will match the FPP start channel on the Inputs.
    Folsom, CA, USA
    2,150
    You did not have e131 output enables so I did not look at it....FYI: your output is the LED Panel screen. Best to remove e131 output entries.
    FPP is outputting test to P10, so I suggest you look into xLight. Iím not an xLight guy
    Not sure FPP receives bridge mode data via Multicast
    In Lights Therapy
    Folsom, CA, USA
    2,150
    I set my Pi to bridge with the following 2 screens and got my P5's to work. LED Panel screen is still needed. (yours was good)
    Correct: you can use Multicast from computer to FPP
    In Lights Therapy
