Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Matrix Upside down
    Nov 2014
    Close to Hillsboro, OR
    480
    Default Re: Matrix Upside down
    Since I haven't seen this answer/response yet...after you switch the output on your matrix layout in xLights to a different position (i.e Top Left to Bottom Left), did you perform a *Render All* to make it "take"? You should also go to the Layout tab and hit the Save button at the bottom (it should be lit up in red because you changed something) and then do the Render All. I had the same issue a couple weeks ago and was reminded of this.
    Sep 2018
    8
    Thank you all. We got it fixed. Robert at www.holidaysequences.com called and helped. Seems I was trying to import the .lms file when I should have used the .avi file.
    Again, thanks guys
