Results 1 to 10 of 12
Thread: Matrix Upside down
    Sep 2018
    8
    Default Matrix Upside down
    Recently bought the " Bob Seger-Little Drummer Boy" E1.31 Matrix sequence from HolidaySequences.com. When I can make it display (50% of the time I try) it always displays upside down. I have bought 2 other E1.31 Matrix Sequences for the same company and they work fine. I have set the "start location" in xLights to all 4 starting locations, sometimes I get something (always upside down), sometimes I get nothing.
    My setup...
    xLights Version 2019.40 74 bit
    Falcon F16V3 Using 12 ports in Zig Zag mode.
    FPP Version: v3.0 Host: FPP-1
    RGB Pixel Matrix Board 24x50
    Matrix is on Output 1 of the F16v3.
    No other sequences running, totally stand alone.
    Ideas, please?
    Thank you
    Bill
    5,800
    Default Re: Matrix Upside down
    Flip the matrix over !
    Sep 2018
    8
    5,800
    You don' specify vertical or horizontal , so flip is the closest I could think of .
    I do not mean physically flip , I mean configuration wise !
    Sep 2018
    8
    Horizontal. How do I do a flip?
    thanks
    5,800
    Well you don't say what software your using though regardless it appears that your configuration is not correct .
    Redo your configuration in a different order and save it , then try it again in display viewer etc.
    Sep 2018
    8
    As noted in first posting....
    My setup...
    xLights Version 2019.40 64 bit
    I have complete removed xlights and all it's files and reinstalled twice, I have redone the setup page and the layout page twice. I have 2 E1.31 Matrix Sequences from the same source working like they should. This 3rd one is for some reason upside down.
    Help???
    THank you
    5,800
    Whoops , didn't see the lower text .
    if horizontal , swap the rows from bottom to top .
    Your actual matrix should be wired to suit your configuration along with your controllers configuration i believe.
    Sep 2018
    8
    Found out how to flip left to right and up and down. Still displays upside down. I have even reversed the cables, I.e. moved cable 1 to output 12 and 12 to 1 and so on, still upside down.
    5,800
    Well it is beyond me as I don't use xlights though I wish I could help further . Hopefully a user will chime in with answers .
    Hang in someone will have resolution .
