Results 1 to 9 of 9
Thread: Ws2811 Pixel string
    Oct 2015
    Hastings, New Zealand
    18
    Default Ws2811 Pixel string
    Hi I'm just clarifying:
    Do WS2811 pixel strings run a controller per 3 nodes in a similar fashion to the WS2811 LED strips?
    I'm looking to buy these https://www.aliexpress.com/item/32932655554.html
    It looks like there is a controller per each pixel as per the photo. I asked the seller the question and he didn't really answer the question. I don't think he understood the question.
    Duane
    1,360
    Default Re: Ws2811 Pixel string
    Each node has an ic chip so each node is addressable.
    Sent from my ASUS_A009 using Tapatalk
    47
    Ws2811 pixels have one IC per node. Which can be addressed individually.
    Jan 2018
    170
    Quote Originally Posted by nzchristmas.nz View Post
    Duane
    You can get a better quality at a better price from Paul or daniel out if china.
    3,633
    Duane
    You are making a set of classic mistakes in your explanation. Each WS2811 IC / Chip is a single RGB Driver 'node'. NONE of these driver nodes are addressable. In fact they are more like the Renard protocol in that each node consumes 24 bits of data (8 bits for each of Red/Green/blue) and then passes the rest of the data through to the rest of the string. If you cut out a 'node' then the next node in the string takes it place in the data consumption hierarchy.
    Typically a WS2811 'node' drives one or more Tri-Color (RGB) LED devices. A WS2811 based bullet node usually has a single Tri-color LED connected to the WS2811 driver. Many 12v WS2811 based strips use three Tri-color LED devices connected in Series to the WS2811 Driver. I have seen strips with five Tri-Color devices attached to the WS2811 pixel node.
    In our current usage of the term "controller" we tend to mean the device that converts the data from the show player into a "bit" stream with the proper timing to drive the WS2811 driver chips in your string.
    Martin
    Oct 2015
    18
    Dim Bulb, Thanks for the suggestion. Do you have links to them, please?
    Mar 2015
    Bloomingdale Ga
    120
    Just do a FB serch for Paul Zhang.
    Sent from my SM-G900V using Tapatalk
    Rayhjr I Love This Stuff!
    5,880
    Duane
    They look good and that seller has great reviews . I may order some myself !
    Oct 2015
    18
    Yeah, all my strip leds have /are coming from him. So far So good.
    Sent from my SM-A520F using Tapatalk
