I have an idea that might help with this problem. Check the instructions below:
- Shape a flat bar or metal pipe into a ring or triangle about ½ cm bigger than the diameter of the radio antenna - just big enough for it to slide up and down easily around the radio antenna. Ring shape is preferred for lesser resistance sliding up/down. Also, metal pipe will make it easier to drill and attach hooks for lights
- When using a pipe, ends can be connected together by inserting a short rebar inside the pipe and secured with a small nail or screw
- Drill holes around the ring/triangle to attach hooks for the lights and wire rope. Make sure that the hook placement will not interfere when the ring slides up and down.
- Attach 3 pulleys to the top of the radio tower - one on each corner (assuming it is a triangular shaped radio tower)
- Attach 3 30-32ft long wire ropes to the ring/triangle and thread onto the pulleys.
- Make a loop at the end of each wire rope and secure it with a wire rope clips (2-3 clips each).
- Attach the 3 wire ropes to another wire rope coming from a winch that is secured near the base of the radio tower
Suggested Materials:
Wire rope:
https://www.harborfreight.com/search?q=wire%20rope
Winch:
https://www.harborfreight.com/1000-l...nch-65688.html
https://www.toolots.com/julun-hand-w...with-hook.html
Pulleys:
https://www.lowes.com/pd/Blue-Hawk-R...lley/999971150
https://www.lowes.com/pd/Covert-3-in...ulley/50427016
