I was cross referencing the lines that needed to be added for unicast, but could find where in the original code to add them? After all the define information?
i missed the adding of this line in setup for static ip .
Code://IPAddress ip (192,168,1,105); // xx,xx,xx,xx //IPAddress netmask (255,255,255,0); //255,255,255,0 is common //IPAddress gateway (192,168,1,1); // xx,xx,xx,xx normally your router / access piont IP address //IPAddress dns (192,168,1,1); // // xx,xx,xx,xx normally your router / access point IP address void setup() e131.begin(ssid, passphrase, ip, netmask, gateway, dns); /* via Unicast on the default port */ //e131.beginMulticast(ssid, passphrase, ip, netmask, gateway, dns, universe); /* via Multicast for Universe 1 */
like this will work , and add the line above to > void setup < in with the other lines for e131.
Code:const char ssid[] = "UNSECURED ????"; // replace with your SSID. const char passphrase[] = "NOTMYWORDPASS"; // replace with your PASSWORD. const int universe = 1; // this sets the universe number you are using. //IPAddress ip (192,168,1,105); // xx,xx,xx,xx //IPAddress netmask (255,255,255,0); //255,255,255,0 is common //IPAddress gateway (192,168,1,1); // xx,xx,xx,xx normally your router / access piont IP address //IPAddress dns (192,168,1,1); // // xx,xx,xx,xx normally your router / access point IP address
Here's the finished result https://youtu.be/iBllIS7s8M4
Sent from my YAL-L21 using Tapatalk
Video not available. Sorry.
