Results 1 to 5 of 5
Thread: pixel string length
    Apr 2019
    Justin Texas
    80
    Default pixel string length
    It seems all the pixel strings are sold in groups of 50 or 100. One of my projects is a couple of arches. They do not require 50 pixels. Can I cut off where I need to then solder the unused part of string onto another one to create custom lengths or are they internally addressed someway? I see how to make random lengths in the controller software so that is not an issue. Thanks.
    Jan 2019
    Honokaa, HI
    14
    Default Re: pixel string length
    Aloha,
    I'm still pretty new at this, but I'm 95% sure you can cut and resolder. I was planning on doing that at least from my 250 spool to make the lengths I need.
    4,411
    min string length is one pixel. max string length is infinite. anything in between is fair game. there are other things that limit you. about 600 pixels in a string is the limit for a 25ms refresh rate. most controllers will limit you to about 1000 pixels on a port. some controllers more others less. you need to inject power which places a practical limit on your wallet.
    contrary to advertising, the pixels are NOT addressable. the data a pixel gets is determined by its position in the string. cut one out and the next one moves up in line.
    May 2016
    327
    And if you don’t want to cut and resolder, a couple vendors make custom length strands with connectors attached already. Custom length is the way to go if you have lots of props to build, IMO.
    Apr 2019
    Justin Texas
    80
    thanks for the replies. I was pretty sure that was the case.
