Results 1 to 9 of 9
Thread: Looking for ideas/inspriation
    Jan 2019
    Honokaa, HI
    14
    Default Looking for ideas/inspriation
    Aloha,
    I'm new this year. I started out smallish. I have a roofline on my house and my separate garage and an 8ft megatree 90ish degrees with 9 strands. I'm looking to sequence https://www.youtube.com/watch?v=e9GtPX6c_kg as my first one. But for the life of me I can't think of how to make it interesting with just those three elements. Most examples have dozens of elements. How did you get started, any ideas on the how to make a (mostly linear roofline) more interesting?
    Mahalo,
    Sam
    Chambersburg, PA
    707
    Default Re: Looking for ideas/inspriation
    Quote Originally Posted by samami View Post
    Aloha,
    Mahalo,
    Sam
    Sam,
    sorry for not answering your question, but my question is where can I purchase a copy of that song? I can't find it anywhere other than Youtube.
    2016 - No Display
    Jan 2019
    Honokaa, HI
    14
    Aloha,
    No worries. I found the whole album here. https://thepianoguys.com/collections...y-christmas-cd or on google it looks like you can buy just the one song. https://play.google.com/store/music/...jyz2j2vykwwdky
    Houston, TX (near Katy)
    983
    That's a feature not a bug.
    There's no charge for that.
    Lombard, IL
    657
    For inspiration I also use Youtube. Search the group and Christmas Lights. Like "Piano Guys Christmas Lights". Also the song done with Christmas lights. It may not be the same but you might be inspired but by another version of the song and pull that into your's. I would also search "First year Christmas lights". See what others have done with their first year setups. You might find elements like your's and can apply them to the sequence. See tree affects that you may be able to do and adjust to fit your layout and song. Sometimes it also pays to just play in the software, put things together to see what looks good. We then keep them and use them later in songs. My best suggestion is to be sure to make up an accurate preview. The closer you come to what your display will look on your house the more accurate the end product will look when you run your show. Last, have fun. Don't fight it. If you get frustrated, put it away and come back. It always helps.
    Welcome to the madness!
    1,206
    A few suggestions...
    First, think of your house as having strings of LEDS. How many "strings" can you break up the roofline into? Now that you've done that exercise...maybe you want to repurpose the mega tree? A handful or two of 25-50 pixel elements might be much more interesting than a 9 string mega tree. Or maybe hang the nine strings off your roofline? Just some ideas.
    Use single color with various brightnesses. One way to do that is to develop a pallette of similar colors with various tones and brightness. Then, when you do a "fan" effect, you can run the various tones across the whole scene using a moving center point. Think that would be cool
    Use traditional coloring to make make your strings look like traditional lights and use the aforementioned "strings" to run various (alternating) patterns.
    Turn off one or more elements for "long periods" of time.
    Use the "glitter/sparkle/strobe" effects to add depth to whatever you are showing.
    Use really slow movement.
    Ping pong the "strings" as if they were arches.
    Do the whole song using only red, green and white (look up holdman christmas lights for example).
    Buellton, California
    365
    Not sure if you're using pixels or incans/led (assuming pixels). I would think about doing several mini trees or smaller elements if using pixels. The more elements you have the more you can do with the display when it comes to sequencing. You can do a lot with 8 mini trees with pixels. I don't think you'll be happy with a 9 strand Mega Tree.
    Jan 2019
    Honokaa, HI
    14
    Thanks for the encouragement and ideas folks. I had just started considering re-purposing the mega tree. Currently it's a 250 pixel spool so it can be whatever I want. Maybe I'll shoot for some smaller trees and/or a handful of arches.
    -Sam
    Mar 2014
    Plano, TX
    94
    Most people that you see their displays started small and with each passing season they add more. With what you have now, I can say that you are actually starting "big". I will advise you to not re-purpose your mega tree. Mega tree is always the model other models are built around. If you can afford your mega tree to be say 16 strings of 50 pixels that will be 800 pixels, with your house outlines, you will have really good model to sequence to.
    Unless you are really good with xLights, I will suggest that you start first with pre-made sequences (maybe 2 or three, although the are expensive!!!), with pre-made sequences, you don't have to spend a lot of time figuring out xLights and you can learn a lot by studying these pre-made sequences and let us not forget that you will have excellent professional display.
    This is a very good forum with a lot of excellent experience folks, willing and able to assist you.
    Best of lucks.
