Results 1 to 10 of 10
Thread: Pex tubing
    Nov 2008
    Southeast Texas
    66
    Default Pex tubing
    Are all brands the same as far as translucent properties?
    Home Depot in my are sells Apollo brand pex with no markings on the outside.
    100 foot rolls are $45 for 3/4
    Is 3/4 big enough for pixel strips?
    2,707
    Default Re: Pex tubing
    I have not seen any difference between the offerings, other than color. Colored PEX tends to be less translucent than the white, by a lot.
    3/4" is big enough for pixel strips.
    It may be too tight of a squeeze for bullet nodes.
    Nov 2015
    187
    you are going to want to go with 1" pex. not sure if you are into 3d printing, if not, there are several guys avail for hire, BUT there are a few really good models of 3d printed bases for 1" pex pipe on thingiverse. i use pixel strip in 1" pex and am toying with the idea of nodes inside of pex. i've tested 1" with little room to spare, so i wouldn't venture to try it with 3/4".
    Buellton, California
    357
    I've used the 3/4" SharkBite from Home Depot with IP67 and IP68 strip. Not fun... I would recommend minimum of 1" for arches. I went to nodes last year due to massive failures with strip... 1" worked for nodes as well.
    Nov 2014
    Close to Hillsboro, OR
    440
    I used 3/4" white PEX from Home Depot with strips for arches and had no problems. It took a couple minutes of wiggling and jiggling to get the strip all the way into and through the tubing but I didn't have to do anything to anchor or hold the strips in place - they didn't move or twist. Maybe I just got lucky...?
    Nov 2018
    Leicester, UK
    17
    Do people generally prefer the diffused look of tube hoops, or the more random pixels wrapped around the outside of a hoop (Trista Lights style)?
    West Bloomfield, MI
    660
    Quote Originally Posted by Steve Ratcliffe View Post
    I think you will find folks in both camps. For mine, I used strip inside 1" PEX for a more diffused look.
    Ed
    Happily retired
    2,707
    The 3/4" shark bite PEX works just fine with strips. Our "PEX Tree" is made from it. 5 meter (~16.5 feet) strips mounted inside.
    Note that we used a rod to pull the strips through the PEX. Bought the 20 foot PEX tubes from True Value Hardware.
    Plugs for 3/4" to close both ends if the PEX are readily available here.
    If you are doing arches or the like, 1 1/2" (or larger, e.g. 2") HDPE works great. Getting some of the 3D printed feet is a good thing. Lots of other methods to choose from.
    87
    If you use 1 1/2" HDPE rebar caps work great for feet. Available at any Home Depot, Lowes or Menards. Cut 4 - 1 1/2" slits in the bottom of the tubing. It allows the rebar cap to slip inside the HDPE. Screw the caps to a piece of deck board, stake it down. Works great.
    Nov 2017
    137
    1" pex will allow most pigtails to pass through. 3/4 wont. I solder / seal all my pigtails on the workbench and then work through the PEX. Makes life a bit easier...at least for me.
