Results 1 to 8 of 8
Thread: New to Arduino and Prototyping
    Chambersburg, PA
    746
    Default New to Arduino and Prototyping
    I have been working on a Non-Light Display project using an Arduino and electronic scale to control a DC Motor. My experience with electronics has been as a technician following steps in a premade kit with fully designed PCBs. I am ready to take my project from breadboard to a more permanent solution, but I am not prepared to design a circuit board. So my question is with a two-sided perfboard what is the best practice for making something like a ground plane, or 5V plane? I have seen solder bridges but wondered about other solutions.
    2016 - No Display
    Jan 2018
    7
    Default Re: New to Arduino and Prototyping
    This may not be what you're after, but I spent a while messing with stripboard/perfboard until I discovered jlcpcb.com - You can throw PCBs together using KiCad (open-source) or their own web-based EDA thing, and have 5 PCBs made up (24 hours) and shipped (slowly) for very little money - I'm waiting on a bunch right now which cost me less than £6GBP (~7.50USD) shipped to the UK. I think they'll even ship the components alongside the boards if you export from their EDA to their supplier, although I've never tried this.
    There's a bit of a learning curve, but the end result seems solid - definitely more reliable than anything I slapped together with stripboard. Frankly, if I can produce something usable, anyone can, and if you end up needing to respin the board, it's pretty cheap.
    (For the record, I've no affiliation with anyone mentioned, just a happy customer)
    Chambersburg, PA
    746
    Quote Originally Posted by PeteMatthews View Post
    Thanks for the suggestion, but for the moment I am just looking for a more robust method of wiring my circuit while I continue testing and making adjustments to the design.
    2016 - No Display
    6,388
    Maybe these might interest you .
    Pad Per Hole and Ground Plane 2 sides .
    VECTORBORD® CIRCBORD® PRINTED CIRCUIT PROTOTYPING BOARDS
    http://www.mouser.com/catalog/645/usd/2312.pdf
    https://www.tindie.com/stores/SpeedyLab/
    Chambersburg, PA
    746
    Thanks again. I guess what I am really trying to ask is,
    When using a 2 sided perf board for making a semi-permanent circuit, is there a better way to connect several grounds together other than running solder bridges?
    2016 - No Display
    Southern California
    940
    You can lay a length of wire across several of the pads and then solder to each pad.
    Kevin
    5,344
    I'm not sure what you're asking, but one thing that comes to mind are T107 bus strips from Vector Electronics, although they may be hard to find at a decent price.
    Dec 2017
    Southeast Missouri
    17
    Take a look at solar tabbing wire
