Results 1 to 7 of 7
Thread: Seeking source recommendation for RJ-45 Bulkhead Connectors
    Ashburn, VA
    435
    Default Seeking source recommendation for RJ-45 Bulkhead Connectors
    I am looking for a source for inexpensive Cat5 RJ-45 IP-67 (at least water resistant) panel mount (AKA: bulkhead mount).
    M20 is a nice mounting hole size. Dust caps are a bonus.
    I need 40+.
    I am hoping for under $3 each, shipped to USA, 20147.
    Here is an example
    I am hoping somebody has a specific source that they have experience with and can recommend. I have started searching AliExpress and found hits but I think AliExpress is kind of a crap shoot. I have had mostly good experiences but a few where it would cost more to make it right than it was worth. Since I am looking at $100+, I don't want hassles.
    Nov 2017
    142
    Default Re: Seeking source recommendation for RJ-45 Bulkhead Connectors
    These are the ones I ordered:
    (EDIT) Dang - they went up since I ordered - :-( should have ordered more!
    Folsom, CA, USA
    2,136
    Bulkhead mount IP67, but M25 - should be able to negotiate a better shipping rate and get them landed $3 or less.
    https://www.aliexpress.com/item/9314...AbTest=ae803_3
    These are a little higher, but 100% rated.
    https://www.aliexpress.com/item/3286...AbTest=ae803_3
    In Lights Therapy
    Oct 2012
    Seattle
    81
    Are there compatible ends that go on the cable to be connected? Have a link for them?
    How are the threads on these and ease of screwing the connectors on? I got some off Ebay and they work but it takes some effort to get the connectors screwed on.
    Folsom, CA, USA
    2,136
    Quote Originally Posted by craiz View Post
    The ones I list screw great. Suggest you try some dielectric grease on yours.
    In Lights Therapy
    Aug 2013
    Madison, AL
    281
    These are the ones I am using. M20 size, IP67, panel mount. Slightly over $3 each (but not much). I've been very pleased with them.
    https://www.aliexpress.com/item/1887...20bb4c4dJjAuZb
    Keith
    Keith
    Ashburn, VA
    435
    I know a lot of others have been through the process and I was hoping to piggyback. Thank you everybody for your suggestions.
    One of the difficulties I have in sourcing a part is that I have a huge number of resources on which to draw. Searching can become dependent on something as simple as searching for "bulkhead" vs "panel mount".
    As a side note, I don't use the mated cable end cover. I make a shroud from a piece of bicycle inner tube tightly zip-tied to the exposed threads of the bulkhead connector. My boxes are mounted so the RJ-45 connections face down and the shroud protects them.
