Results 1 to 7 of 7
Thread: Has anyone tried these?
    Kansas City Missouri
    2,023
    Default Has anyone tried these?
    I know I can use a network switch to drive 2 controllers but then I noticed this. So let's say I have a 682 and 6804 in one box. Instead of a network switch can I use this to supply a network to both controllers?
    Nov 2012
    Wenatchee, WA
    455
    Default Re: Has anyone tried these?
    That splitter won't work for your needs. They do make splitters that do what you need but you need two of them. This article has a good picture and explanation of how it would work.
    https://eastmanreference.com/the-dif...itch-and-a-hub
    1,051
    Have not used that version but years ago we did something similar at work. Should work.
    May 2016
    Marble Falls, TX
    72
    It could work, but it would not best practice. If you are running multicast itíll probably be ok since multicast typically floods the network with data anyway (unless your network and devices support IGMP- probably not). If you are running unicast you will have packet collisions and be running on reduced bandwidth. Think of a hub as multiple people all talking at once - itís hard to understand everyone. Switches are like moderators to help direct conversations and make sure everyone is heard. Switches are cheap. I know it means you need room and power for another device, but I believe the benefits outweigh the risks.
    Mar 2010
    Mentor, OH
    1,134
    Just get one of these
    They are small, cheap and work good. Itís 5 volt. I have them installed in all my boxes.
    Chuck P
    nothing to show
    2,023
    Thanks folks. I was just wondering if it would work. I'm running Unicast so that there alone wouldn't work. I have several small network switches but just wanted to know if those were feasible.
    3,633
    CAT5 negotiation protocol is a point-to-point mechanism. Splitters like that do not allow the DXE negotiations to work.
