Thread: Matrix Mounting Help
    Jul 2013
    116
    Default Matrix Mounting Help
    This will be my first time using a matrix. I have a 24x48 panel from HolidayCoro populated with bullet pixels. What is the best way to mount it to the front of my house? I know I need to build a frame and will probably use PVC. The front of my house is all veneer brick.
    1,539
    Default Re: Matrix Mounting Help
    There are Brick Clips or you could drill holes and use anchors to hold it.
    If you are using PVC you could just extend the sides down to the ground to support the Matrix. You could hang it from your eaves
    Jul 2013
    116
    Thank you. I think I will just build the frame with feet and secure it into the ground. Don't want to drill into the house.
