Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: Ws 2812b pixels to control Dc motors
    6,073
    Default Ws 2812b pixels to control Dc motors
    Have many of you taken on this endeavour ?
    After a few weeks of playing with this idea , I have finally figured this out so I can be simply sequence motors along with the rest of the display .
    I had originally thought motors used in displays would be common place and that folks would be using a something directly related to this hobby in doing so .
    Not being a coder and tutorials related to this are minimal at best .
    I have enjoyed the learning curve in doing this , though it would be nice to see via e1.31 for pixel control .
    Cheers
    3,892
    Default Re: Ws 2812b pixels to control Dc motors
    lots of people do motor control via e1.31. FYI: ws2812 does not have the outputs connected in a way you can use them. WS2811 gives you want you want. In this case you get three PWM outputs to use as you please. But most motor controls cant make use oof PWM outputs. There is a project that takes WS2811 output and binds it to some triacs to make a ws2811 driven ssr which could be used to drive a motor
    6,073
    You are correct in the hardware I used a 5v ws2811 pixel board . I have sequenced using the ws2812b selection just as the pixels being used.
    My mistake for the poor clarity
    The excitement of getting it working via trial and error clouded my post , sorry for that .
    Oct 2009
    712
    Check this out - it might be what your looking for.
    https://www.youtube.com/watch?v=UijLGeUGpOk
    https://www.pixel2things.com/
    6,073
    Quote Originally Posted by covewi View Post
    Thank you for posting this .
    I posted this as an interest thread to see what others are doing .
    The links are exactly what this thread needs
    So far I am content in using the nodemcu which works well and permits pixel level control wirelessly .
    As a test setup , I used LedFx on an android and nodemcu to prove my thoughts .
    All works as suspected so implementing into any sequencer of choice ( in my case HLS ) will be a breeze .
    Nov 2015
    The Netherlands
    77
    i'd like to control a stepper motor from e1.31 to make a kind of dmx-winch. I'd like absolute control meaning 1 in the channel is position 1 and 254 in the channel is position 254. I tried this half a year ago and got some rudimentary movement. I have to call in my neighbour to help (he's a programmer)....
    Errors for fun only.
    3,892
    You will need some sort of controller to translate desired position to motor pulses and track the current motor position. There is a bit more to it than saying 1 is al the way to the left and 255 is all the way to the right.
    6,073
    Quote Originally Posted by kockie View Post
    Hi kockie
    I have managed to get stepper motors working now with code that can be simply added to the espixel firmware .
    If you are looking for something functional to test with .
    Cheers
    Nov 2015
    The Netherlands
    77
    Hi kockie
    Cheers
    iI'm interested for sure!
    6,073
    I am happy to report , you have your winch !!
    forward , reverse .
    on/off-energize and ramp from 0-255
    Simple control via color intensity .
    Code:
    Stepper Motor Control
    with L293D ic & 1 x ws2811  pixel boards
    #include <Stepper.h>
    // Set steps per revolution
    const int stepsPerRevolution = 32;  //<< Set to 1/2 of your stepper's rating if using stepper.h library for normal speed , or increase for faster speeds
    const int PWM_PIN = 14;  // PWM INPUT.   red  channel
    const int PWM2_PIN =  12;  // PWM INPUT  blue channel
    /* Motor >>>>> in pins 15-5  Pins from motor to L293D
    connection order on ic 4,3,2,1    */
    Stepper motor1(stepsPerRevolution, 15,13,4,5);
    void setup() {
        // Initial pin states
        pinMode(PWM_PIN, INPUT); // pin 14 red channel sensor
        pinMode(PWM2_PIN, INPUT); // pin 12 blue channel sensor
        int Bsensor = 0;
    void loop() {
        // MOTOR 1 CONTROL
        int speed = 0;
        int direction = 1;
        int position = analogRead(14);  // forward position sensor
        int Bsensor = analogRead(12);  // reverse position sensor
        Forward steps
        if (position > 0 ) {
        speed = map(position, 0, 1023, 0, 255);
        Reverse steps
        if (Bsensor > 0 ) {
        speed = map(position, 0, 1023, 255, 0);
        direction = -1;
        //  Movement
        if (speed > 0) {
        motor1.setSpeed(speed);
        motor1.step(direction);
    Last edited by angus40; 07-27-2019 at 05:14 AM. Reason: Simplified to 2 input pins for ez control
