Results 11 to 13 of 13
Thread: Two power supplies question
    Kansas City Missouri
    2,487
    Default Re: Two power supplies question
    You can always eliminate a power supply by switching to server supplies. Last year I switched to 12 volt 750 watt 62 amp supplies and I love them. I run over 1500 pixels on each at 25% output and they work great.
    Anchorage, AK
    356
    I also use 1 server supply for a 1200 pixel megatree. Works great, form factor is slightly different but one server supply takes up less space than 2 of the standard supplies. And no need to isolate the V+ side from a second supply. I also run at 20-25%. With the breakout board I use, it gives me many screw terminals for outputs.
    2,487
    Quote Originally Posted by aknflyer View Post
    My breakout board has 24 outputs. Just plug them in. I bought it at parallelminer along with 14 and 16 gauge wire with connectors.
