Thread: New to arduino
    Oct 2015
    Hastings, New Zealand
    76
    Default New to arduino
    Hi. I've been doing a display with older grinch hardware and I'm now wanting to start again with arduino and individual addresses led strips.
    Ive seen a series of videos where a node mcu is used.
    My questions are will node mcu work with vixen 3?
    Will I need an arduino board or is the node mcu actually an arduino?
    I'm looking forward to getting into this.
    Cheers
    Duane
    1,322
    Default Re: New to arduino
    A nodemcu is arduino compatible programming. But since it ESP based, you should look at ESPixelStick software (https://github.com/forkineye/ESPixelStick). So long as you use e1.31 you can use Vixen and the nodemcu together. You cobble together other protocols but no need.
    Thread to other similar question: http://doityourselfchristmas.com/for...extra-hardware
    Also there are other projects based on the nodemcu. I think someone did a multi output controller based on nodemcu but I can't find it right now.
    Oct 2015
    76
    Thanks for the advice.
