Results 1 to 10 of 10
Thread: Pixel Icicle Troubleshooting Help
    27
    Default Pixel Icicle Troubleshooting Help
    I already cut up 4 out of 7 strings that I thought had dead pixels. I should've tested after cutting the first one! When I cut out the dead ones pictured, they work fine when connecting directly to the controller. Also, the 3 remaining strings I have, got the same exact pixels that are "dead". I'm 99% sure if I cut them off, they'll work fine if connected straight to the controller. What's going on?? I also injected power at the end of the string thinking it was a power issue, but that did nothing. Voltage at the end of the cut string as well as the untouched strings are 11.8v-11.9. They are 2811s 12v.
    2,875
    Default Re: Pixel Icicle Troubleshooting Help
    How are you testing them? What physical controller? Could it be set for a number of pixels or number of channels lower than the length of the string?
    27
    It's an F16V3 in test mode. Didnt even think about that! But when I tried plugging in a string at the end of one that I had removed 1 from, about half of the second string lit up. So that was about 30 more than a single string.
    2,875
    Can you post a screen shot of your controller settings? In particular, the output page(s). If you are testing directly from the controller (and not from a sequencer), the test page as well.
    27
    Just ran it right out of the package! Feeling pretty dumb right about now because I'm pretty sure that's the problem and I just cut up 3 perfectly good strings! I'll check out the settings. Thanks for the help!
    27
    Ok just confirmed that I'm a moron! It was the controller settings! Now to solder back what I cut! At least one of the strings actually had a dead pixel! Thanks again!! I would've never even thought about that!!
    2,875
    This is a lesson many of us have learned. Some of us have relearned it. And relearned it. And .........
    Winter Haven Florida
    3,039
    Quote Originally Posted by Executive8468 View Post
    Been there done that!
    James WinterHaven Fl
    Jan 2013
    Northern Illinois
    299
    I’ve done it more times than I have fingers and toes.
    27
    Thanks everyone! I feel a little better knowing I'm not alone!
