Results 1 to 2 of 2
Thread: Need help on a Non-Christmas project
    Nov 2007
    Houston, TX (near Katy)
    942
    Default Need help on a Non-Christmas project
    Hi..I am trying to use a raspberry Pi to catch a triggered event (a closed switch such as a pressure switch) and email me if the switch is triggered. I currently have an outside pressure tank and would like to be emailed is the pressure drops below a certain point. I think I have the necessary hardware, but know nothing about python, or any other scripts for that matter and am looking for a nudge to get this project started. I look to this community because of the help you have given so many others in the past. I will pick it up quickly, but need some help getting started. I appreciate any input.
    I do see scripts for a triggered event, and an sSMPT script. I can get the Gmail account, but again, I don't know what programs to start with on the Pi.
    thanks again.
    That's a feature not a bug.
    There's no charge for that.
    3,513
    Default Re: Need help on a Non-Christmas project
    you need to collect a few bits of software together. Python has a facility for sending emails. Find an example for it. The look into how the timers work in Linux. There is a mechanism for running a program every N seconds (can be days work weeks or every day at 1:03 AM etc). It is called a cron job. You create your cron job to fire however often you want to check the input. You did not mention how the sensor is attached to the PI. If it is via a digital input (on / off) then you would use python to call wiringPi to get the current state of the input. Then your program decides whether it should send an email or not.
    So cron calls your python utility, python calls WiringPi and Email.
    The above is called "Polling". It reads every N period of time. Writing code that is event triggered is a bit more difficult. Polling should meet your needs.
