Results 1 to 5 of 5
Thread: Automatic Soldering Gun
    Miami, FL
    39
    Default Automatic Soldering Gun
    Hey anybody have any luck or even seen this before?
    https://kiaralane.com/products/auto-...kEFrGvxsO2eZoA
    North Richland Hills TX
    630
    Default Re: Automatic Soldering Gun
    I haven't but looking at the video, I do have a concern. Proper technique is to place the iron to heat the surface to be soldered. Once heated applying the solder the the surface, not the iron itself, this avoids cold solder joints and draws the solder into the wire. Based on that technique, I'd stay away from this tool. The other reason is I'd pass is it's too big to control for detailed items like running a jumper wire on a pcb.
    630
    I always use the following guideline, buy the best tool I can afford for the given task. Buy once, Cry once.....
    6,388
    Quote Originally Posted by benny1495 View Post
    I added this and it is better than my hakko .
    630
    I have the same and enjoy soldering, the hot air attachment now gets more work than the iron. I now do a lot of smd work.
