Results 1 to 7 of 7
Thread: Custom Prop Editor set up
    Mar 2017
    Clinton Twp. Michigan
    92
    Default Custom Prop Editor set up
    I have been playing around with the Custom Prop Editor in Vixen 3.5. I made a prop. The prop is a face and I am not using pixels just Christmas lights. I added my light to the prop editor but can't see how to make them work as one element instead of 73 individual lights.
    Tony
    1,526
    Default Re: Custom Prop Editor set up
    In the preview you just have to map all 73 lights to the same output, or if you have several outputs (eyes, lips...) then all the lights for each feather to the appropriate output. It would be nice to be able to select several individual lights and say "Create String".
    Maryville, Illinois
    1,733
    You can associate all lights in a string to a single element within the custom prop editor. Add a element or a single light that creates the element. Then select the element just added and continue adding lights. All those lights will be associated to the one element and make a "string". You can create multiple strings for say a face that has a "string" per face part. Under Physical tab in the prop editor set the Color Type to Single Color or Multi Color depending on how you want the color handling setup on the strings. Then when you import it into the preview each string will be one element with all the lights you created associated to it. It should ask you about the color handling when you add it and you can set it up the colors just as you would conventional strings if you created them in the Display Setup. The color handling is a bit generic to the whole prop, but once you import it if the separate strings need different colors, you can adjust that in the Display Setup.
    If I get some time in the next day or two I can create a video showing the process, but hopefully that helps get you going.
    Mar 2017
    92
    Thanks for the help got it to work I think
    May 2019
    1
    Did you get to make that video, Jeff? I've love to see how this is done.
    Maryville, Illinois
    1,733
    Quote Originally Posted by Buirro View Post
    Still on my to do list, but I will post it here once I do.
    Maryville, Illinois
    1,733
    Here is a basic video that shows how to do it. Hopefully this will help.
    https://youtu.be/XlKm7Ax3Stg
    One note, I found a bug while making this that prevents these types of props from showing in the newer OpenGl based previewer. They do work in the older original previewer. I fixed the bug and it will be in an upcoming dev build in the next few days.
